Brief Description: Ran the Magnetometer Wires Through the Panel
Ran the Magnetometer Wires Through the Panel Holes drilled and fitted with snap bushings. To run the wires, I had to take all of the wires out of the 25 pin connectors and then re-install the wires. The ADS-B bundle will need to be secured under the panel because passing the bundle through the panel hole is out of the question. This bundle is part of the Transponder cable fabricated by Approach FastStacks.
