John (Jack) Clark's Web Site
RV-A8
Soldered 10K Ohm Resistors in Keep Alive Wires
Soldered 10K Ohm Resistors in Keep Alive Wires for the GRT Displays' Clocks.
Soldered a wire on the tray for the PS Engineering PS-5000EX Audio Panel. This wire will be run to the Grounding Hub.
10k Ohm Resistor
GRT Display Clock Power
Keep Alive Power From VP CU
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
