Brief Description: Linked the Forward Grounds Together
Linked the Forward Grounds Together in preparation of powering up the avionics. A lug terminal was crimped onto the 4AWG ground cable that will be later bolted to the Forrest of Tabs that will be attached to the firewall. The Forrest of Tabs is a brass plate will numerous tabs welded/braized to it for the attachment of Faston connectors of ground wires. These ground wires come from the avionics and any other equipment needing a ground. The engine ground will attach with a bolt to the firewall on the otherside of the Forrest of Tabs and the Grounding Cable thus connecting them all together. This grounding scheme is to minimize the possibility of forming Ground Loops that could affect the audio quality of sensitive avionics.
Laced wires of the Right forward Mid Cabin.
Removed the Starter Cable from the Main Contactor and removed all fuses from the Fused Power Panels in preparation of testing indivisual circuits.
