Brief Description: Attached TCW IBBS to the Baggage Bulkhead
Attached TCW IBBS (Intergrated Backup Battery System) to the Baggage Compartment Bulkhead. First I had to make a doubler to insure support of the 2.5 lbs of battery attached to the bulkhead. the IBBS will provide Secondary backup Poweer to the Electronic Flight Information Systems. This power will come on instantaneously when a drop in voltage is detected. It will also provide smooth power to the EFIS displays during engine start cranking that causes a serious drop in line voltage.
