John (Jack) Clark's Web Site
RV-A8
Attached D-sub Connector on Rear Stick Cable
Attached D-sub Connector on Rear Stick Cable and tested continuity of the stick switch wiring. Installed slotted jackscrews for easy removal of cable when the rear stick is removed.
Slotted Jackscrews
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
