Brief Description: Cut the Panel Opening for the Bottom EFIS
Cut the Panel Opening for the Bottom EFIS. It turned out OK also. What I did discover is that there are size variances between each display. To make both fit, I had to enlarge the holes slightly since on of the displays is slightly larger then the other.
