Brief Description: Cut the Upper GRT HX Opening in the Panel
Cut the Upper GRT HX Opening in the Panel. I used a Dremel Cutting Disc and files guided by a steel angle iron fence secured along the desired cut line. Each cut in the panel makes you fear that you are going to wreck the panel. But I must say, I am happy with the results.
