Brief Description: Wired the Switch Panel on the Fwd Rt Side
Wired the Switch Panel on the Fwd Rt Side. I was tired at the end of my attempts to make all of the wires running forward to the instrument panel fit in the spaces also occupied by the switches. I tried securing the wire bundle run to the switch panel cover but this caused several tight wire crossings and a mini Rats' Nest. In other words, I need to think about alternatives to how I will run the wire bundle through the switch panel area on its way to the instrument panel.
