John (Jack) Clark's Web Site
RV-A8
Installed the Fuel Guardian Lights in the Panel
Installed the Fuel Guardian Lights in the Panel a;ppng with its push to test button. This fit well above the avionics stack.
Installed a nutplate on the fwd side of the F-805R-R Bulkhead to secure cables running up the forward side to the instrument panel.
Installed Adel clamps to secure the cable runs forward from the right side of the center section.
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
