Brief Description: Installed the Light Assembly in the Left Tip
Installed the Light Assembly in the Left Tip. I cut the spacers for the right tip assembly screws close to the called for starting width of 1/32". These spacers worked much better. I'll work on the Right Tip Lights later and change those spacers that don't fit well. The Dremel cutoff disk worked out to be the better choice for this task of cutting the spacers. After cutting the spacers, I deburred the edges of the spacers before their installation.
