Brief Description: Installed the Archer VOR Antenna in Right Tip
Installed the Archer VOR Antenna in Right Tip.
Attachment screw holes for the anteena were match drilled and then the holes were countersunk.
The antenna was match drilled to the nutplates and the reinforcement strips. The antenna was captured between the tip's interior surface and the reinforcement strip by the riveted nutplates.
