Brief Description: Drilled #26 Holes in the Tip for #6 Screws
Drilled #26 Holes in the Tip for #6 Screws. Tim held the trailing edge of the left tip in alignment with the aileron while I drilled the holes for the screws. This made a significant improvement in the trailing edge alignment between the tip and the aileron.
