Brief Description: Glassed the Bottom Centerline With 3 Plys of Glass
Glassed the Bottom Centerline With 3 Plys of 9 oz. Glass to connect the two halves. A new centerline cut will be made next.
Made Styrofoam Plugs to fit in the Coolant Radiator Inlets. These plugs will be used to form flanges on the inside of the cowling that will eventually be incorporated into some arrangement that will funnel air to the radiators. I will probably be shooting for an arrangement where the section from the cowling will align with the section extending from the radiator with minimal gap in between the two. This way, the cowling will be able to be easily removed and replaced.
