Brief Description: Installed an Extra Data Plate on Last Cabin Bulkhe
Installed an Extra Data Plate on the top of the Last Cabin Bulkhead, behind the passenger's head, to cover the screws and rivets used to install the canopy block. The data is essentially that which is required on an aircraft data plate but this is a redundant plate. The real data plate is mounted on the fuselage, under the horizontal stabilizer.
