Brief Description: Installed Hand Holds in the Rollover Bar
Installed Hand Holds in the Rollover Bar. This went OK. It is hard to do get all of the dirilled holes to line up as they are drilled straight through the tube. Add to this trying to get matching angles of installation relative to each other. We did manage to get pretty good results with our holes aligning. There does seem to be a slight difference in orientation of the handles relative to each other but, in the end, they are close in alignment and very functional.
