John (Jack) Clark's Web Site
Date:  1-21-2013
Number of Hours:  4.00
Brief Description:  Installed the Heated Seats' Harnesses 1
Installed the Heated Seats' Harnesses.
The Pilot Seat's harness is mounted on the underside of the F-829A-1 Front Seat Floor. The heating pad connectors exit the floor on the left side just aft of the seat back attachment hinge. The control switch is mounted on the right side just forward of the hinge. This places the switch adjacent to the right rear of the seat cushion.
The rear seat harness is mounted inside the right side panel that covers the flaps actuation bar extensions. Both harnesses are rough installed and close attention will be need to insure there is not any conflicts between the rear harness installation and the movement of the flaps actuation arm on the right side. The rear harness connectors to the heat pads exit the panel low and in the aft third of the panel.
Pilot's Heater Harness Installed
Pilot Harness
Pilot Harness
Top View
Top View
