Brief Description: Discovered Geometry of theTwo Panels Differ
Discovered that the geometry of the two panels are different. Apparently, when I traced the openings on the skin, I changed the orientation of the template without realizing it. I like both openings and they both will work well. The only issue is the dyssymetry.
