Brief Description: Started Installation of the Oxygen System
Started Installation of the Oxygen System. Fitted and drilled oxygen tank mounts to the floor panel of the forward baggage compartment. Drilled holes for the installation of doubler patches that will be mounted on the underside of the floor below the mount legs. I cut some scrap 0.060" aluminum into 2" x 4" plates.
