Brief Description: Sprayed on UV Smooth Prime to Empennage Fairings
Sprayed on UV Smooth Prime to Empennage Fairings after lightly sanding the dried epoxy skim coating. The UV Smooth Prime was sanded once it was dry. I re-applied a light coat of the Smooth Prime to fill a few obvious holes. Will sand again tomorrow after it is well dried.
