Brief Description: Applied 3 Coats of Straight Epoxy
Applied 3 Coats of Straight Epoxy after sanded the skirt holes filled yesterday. Teh first coat was applied with a brush then removed with a squeege. The next two coats were applied with a roller. Each re-coat was applied after the prior coat was firm yet still wet. The resulting orange peel appearance of the coats will be sanded to the point that the orange peel just disappears and the surface is smooth. This is supposed to seal all of the pin hole and weave in the skirt.
