Brief Description: 2nd Sanding of Fairing to Shape
2nd Sanding of Fairing to Shape. This sanding went faster because the fairing is close to the desirable shape. This sanding primarily shaped the front and those areas that were filled or covered yesterday.
Sanded the aft end of the fairing to the rough length. Actually, I sanded off the rough edges to a length that I though was uniform across the length. I'll check this later but it look OK for now. I do believe I will shorten it a bit more after I figure out how far I can go and still get a nice fit with the canopy. I closed the canopy and I really like the fit righ now. It looks nice and snug without any noticable rubbing.
I removed a layer of tape and will now sand to this layer as I work on a smooth surface. I may need to fill and sand the aft end of the fairing once I decide the needed length of the fairing.
