Brief Description: Interior Skirt Pinhole Sealing with Epoxy/Acetone
Interior Skirt Pinhole Sealing with Epoxy/Acetone. Applied mixture to the surface and squeeged the mixture off. Waited about 10-15 minutes between the start of each layer application to allow the mixture to become tacky. After each application and squeeging, I lightly rubbed the surface to blend in any ridges of mixture left by the squeegy. The interior surfaces of the skirt are quite uneven. No effort was made to level the surface because I am not concerned with its overall esthetic appearance. It will be functional and if in the future I decide I want to change the quality of the appearance of the interior surface, I will cover it with fabric.
