Brief Description: Applied Micro and Cabosil to the Skirt Exterior Si
Applied Micro and Cabosil to the Skirt Exterior Sides to fill the rather deep spaces within the fiberglass weave.
Finished the sanding of the liquid shim using my new Rigid Dry/Wet Vacuum. I looked at peoples' reviews for the Rigid vs Shop Vac and decided to try the Rigid vacuum. It seems to be a touch quieter then the Shop Vac but not of any major significance. Vacuum noise is not pleasant at any level and this vacuum it no different. I do like the power switch much better on the Rigid. Others complained about the Shop Vac Switch breaking or not functioning. My Shop Vac switch broke/chipped off a piece early in its life. The Rigid has a 20 foot power cord vs the Shop Vacs cord that is about 12 feet long. I do like this.
