Brief Description: Sanded the Left Transitional Area
Sanded the Left Transitional Area that had been glassed and microballooned. Approaching the final shape.
Started to try various methods to mark the top edge of the aft skirt for trimming. The edge needs to be gradual and symmetrical. What I discovered was that the right side of the aft skirt, where the skirt's curvy shape starts, was longer than that of the left side. This was evident as I tried to cut posterboard templates to symmetrically shape the upper skirt edge. I kept getting one side to fit the templae but the other side would be way too short or long. After much confusion and finally some problem solving, I figured out the problem. The right aft skirt was sanded and noe the contours are much closer.
