Sanded the Left Canopy Skirt interior frame liquid shim and the exterior upper lip. A section of the of the upper lip about two thirds aft cracked at the fracture line when flexed. I reinstalled the skirt and applied epoxy and flox mixture to the fracture line. Once cured, I'll sand the interior of the repair and apply a layer of glass over the fracture line for added strength.
Added Epoxy and Flox mixture to the large aft gap between the skirt halves to join the halves. This area will be shaped by sanding and a fiberglass layer will be added to the inside of the skirts.
