Brief Description: Sanded Empennage Fairings with Foam Blocks
Sanded Empennage Fairings with Foam Sanding Blocks that conform to the complex curves of the fairing surfaces. These worked very well for this semi-finishing sanding. I say semi-finishing sanding because I decided to add a thin layer of Awl Fair to the pieces to fill pin holes. I'll sand these tomorrow and probably apply a this epoxy primer coat to reveal any pin holes in the surface.
