John (Jack) Clark's Web Site
Date:  2-28-2012
Number of Hours:  1.50
Brief Description:  Wired the Cowl Flap Control Switch
Wired the Cowl Flap Control Switch with a DPDT (On)OFF(On) NKK Toggle Switch. Power and Ground wires to the switch are split off of the common power and ground for the cowl flaps. These power and grounds were connected in reverse orientation on each end of the switch. The Common Cowl (+) and Cowl (-) wires were routed to the Molex Connector in the Forward Electrical Compartment. With this arrangement, polarity to the actuator is reversible for the extension and retraction of the actuator arm.
Will Be Mounted Near Throttle
Cowl Flap Switch
Cowl Flap Switch
Molex Connection
Molex Connection
