Brief Description: Finished Riveting the Leg Gear Fairing Hinges
Finished Riveting the Leg Gear Fairing Hinges.
The right gear leg fairing fits tighly but it does fit. The alignment pins can be installed after slight mainipulation of the fairing.
Used the string method to align the stiffener for the left leg. I fit the stiffener inside of the fairing for a test fit prior to applying Bondo to the stiffener. The stiffener fit tight inside of the fairing but I was able to insert the hinge pin. I decided to preemptively remove some material from the stiffener to facilitate the fairing fitting.
Bondo was applied to the mating surfaces and left to bond.
