Brief Description: Removed the Hinges from the Leg Fairings
Removed the Hinges from the Leg Fairings.
Filed the holes with some exopy and flox.
Sanded the excess off after it hardened.
Positioned the hinges in the fairings with a constant distance maintained between the trailing edge and the hinge.
Drilled and clecoed the hinge on one side on each fairing. I'll countersink fairings and rivet these sides of the the hinges next. I'll also repeat the drilling, countersinking and riveting the other sides.
