Brief Description: Soldered Wiring to LED Strips for the Cabin Lights
Soldered Wiring to LED Strips for the Cabin Lights. I cut the strip segments to size. Peeled the Silicone top off of the contacts at the ends of the strips. Soldered a Power wire to the 12V location. Then I bridged the RGB points together with solder. Next, I soldered the Power and Ground wires in place, applied some E-6000 to seal the site and applied shrink tubing. All of the lights were tested progressively and in total. All work well using a 9V transistor battery.
