Brief Description: Bent the Canopy Frame to the Fuselage
Bent the Canopy Frame to the Fuselage. The frame seems to fit fairly well so I tried to minimize the amount of bending I was going to do. Each bend has the potential to change the frame somewhere unintented and this was seen but on a small scale. After many small bends and twists of the frame, the frame is the best that we could do to fit it to the fuselage. I would like to see the aft left corner of the frame in another 1/8" but anything we did to correct this ended up twisting the frame and changing measurement elsewhere.
