John (Jack) Clark's Web Site
Date:  10-25-2010
Number of Hours:  3.00
Brief Description:  Started Fabrication of NavWorx ADS-B Mount
Started Fabrication of NavWorx ADS-B Mount. I will be mounting the device in the tail on the left side.
Cut and bent the aluminum sheet that will have the ADS-B mounted onto it. The pieces of angle that will have the mounting panel screwed to it were cut and match drilled to the longeron. The upper screw holes were drilled.
Marked for bending
Marked for bending
In the Brake
In the Brake
Angles drilled and clecoed
