John (Jack) Clark's Web Site
Date:  5-17-2009
Brief Description:  Installed the Trutrak Pitch Servo Bracket
Installed the Trutrak Pitch bracket but need to replace the bearing bolt of the bellcrank. The included bolt is the same size as the bolt already used with the bellcrank. With the addition of the servo bracket, the new bolt needs to be at least an AN4-16 vs the AN4-13A to insure at least one thread beyond the nut. I called TruTrak and they confirmed that the AN4-13A was the correct bolt for the installation. As will be seen, I had to call TruTrak again for guidance. At this time, I was told that them will be including a longer bolt in future hardware kits for the pre-punched RV-8 installations.
Bellcrank bolt too short
Pitch servo atteched to bracket
Short Bellcrank bolt
