John (Jack) Clark's Web Site
Date:  1-22-2009
Number of Hours:  1.50
Brief Description:  Installed the left brake line
Installed the left brake line. Needed to torque the bolts on the gear weldment that attach to the side of the fuselage before I could complete the installation. Waiting longer would make it very hard to access the nuts. The AN-3 bolts were torqued to 25 in. lbs. Orange Torque Seal was applied to the nut and threaded to witness any loosening of the nuts. The brake line nut was torqued to 50 in. lbs. after putting some Fuel Lube on the threaded.
LT + RT brake lines installed
