John (Jack) Clark's Web Site
Date:  11-5-2011
Number of Hours:  1.00
Brief Description:  Installed the Brake Line to the Right Wheel
Installed the Brake Line to the Right Wheel. Used the supplied 1/4" aluminum tubing from Van's. I was considering the use of braided lines but decided to go stock to save wait. If the lines have worked on so many Van's aircraft, I expect it should be fine for mine. I still need to secure the lines by putting a split tube around the brake lines every 12" and then tape the lines to the landing gear leg. The loops of tubing will provide some degree of flexibility.
Top of Line
Top of Line
Line Wrap Around Gear Leg
Inboard View
Inboard View
