John (Jack) Clark's Web Site
RV-8A
Painiting
11-9-2008
Cleaned/Re-primed/etched earlier failed painting p
Cleaned/Re-primed/etched earlier failed painting of interior parts.
Sanded the seat parts that were primed before with 300 grit paper. Sprayed these parts in the booth. So far, these parts are acceptable.
Will paint the parts that were re-primed today after the minimum 8 hours needed for curing the primer.
RV-14A Home
RV-8A Home
6627
Aircraft Related
314
1432
406
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
158
892
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1432
