John (Jack) Clark's Web Site
Date:  10-8-2008
Number of Hours:  4.00
Brief Description:  Poorly painted 1/2 of loose interior parts
Poorly painted 1/2 of loose interior parts. I rushed the process in an effort to use the remaining light that was quickly fading. As a result, instead of spraying a light tack coat on the parts, I forgot to close the paint supply valve on the sprayer and ended up with a way too heavy coat. This caused a spider web effect. Since I was using the Stewart System, I was able to wet sand the paint off of the parts before it substantially hardened. Another lesson learned...take my time and use better judgement to get the best results with the least effort.
