Brief Description: Removed the lower corner bolts from spar
Removed the lower corner bolts from spar and replaced it with a 1/4" hardware store hardware. Did this now because of the difficulty of placing and removing this bolt when inserted from the front to the rear of the spar. With the landing gear weldment and the fuel plumbing in place, this will become more difficult. I plan to insert these bolts from aft foreward.
