Brief Description: Cut and drilled hardwood for the rear rotisserie
Cut and drilled hardwood for the rear rotisserie. I'm using #8 x 3" screws and nuts to hold the wood sandwich together. After the rear rotisserie stand is welded, I plan to countersink the nuts into the front part of the most aft piece of wood and then machine screw the pipe floor flange to this piece of wood. A 1" pipe will screw into the flange and this pipe will be inserted into a 1.25" pipe so that it can rotate. Castering wheels will be welded onto the stand. With wheels on the rear and front, the fuselage rotisserie will be mobile
