Brief Description: Built the Prop Contoller Harness
Built the Prop Contoller Harness connector. Two wires for the Airframe Ground and the (-) Ground (Shield ground) were ran to the area that will have the Forrest of Tabs Grounding on the firewall. The power came from the 4 amp circuit breaker. I soldered an extension on the Prop Sensor wires using 3 x 22ga. shielded wire. This leaves the prop motor power wires to be extended. These I will solder tomorrow.
