John (Jack) Clark's Web Site
RV-A8
Aircraft Related
8-12-2006
Installed T-405 & T-410 to left tank nose
Installed T-405 & T-410 to left tank inboard rib nose then spred proseal over the machine and shop heads. Did the same to the outboard rib's T-410.
Installed the flop tube in the left tank in compliance with Van's Mandatory Service Bulletin No. SB 06-2-23.
Outboard T-410 outside view
SB 06-2-23 compliance
Tape over fuel connection
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
