John (Jack) Clark's Web Site
RV-A8
Aircraft Related
5-22-2012
Corrected Rt Wing MX-150L Electrical Connector
Corrected Rt Wing MX-150L Electrical Connector pin installation. The socket should have had male pin attached to the wires. As it was, the socket and plug does not connect and the plug would have had male pins exposed to potential damage.
Rt side socket with male pins
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
