John (Jack) Clark's Web Site
RV-A8
Wing Construction
6-9-2022
Started/Completed Right Spar Preparation
Started/Completed Right Spar Preparation.
This included fabrication of the J-channels, match drilling the #40 holes for the nutplates then countersinking the holes.
Match drilled all of the #40 holes.
Installed the tank nutplates and the wing inspection plate nutplates.
Countersunk the wing tank and wing inspection plate holes to accept the dimpled wing skins dimpled inspection plates.
Installed rivets and nutplates in the inboard section of the spar. Installed four nutplates in the outboard spar section.
Countersunk all of the #40 holes to accept the dimpled skins.
Primered all of the spar areas that were machined.
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
