Wired the Aft Stick Grip. This required cutting the stick for a wiring access slot in the top of the stick then fitting an adapter on the stick. The adapter is needed because the aft stick diameter is smaller then the front stick and won't fit the grips without the adapter.
Holes were drilled for the grip boss and for the exit of the cable.
I cut the stick length to prevent the stick grip from contacting the temporarily positioned front seat back. Final stick length will depend upon the seat back position and the presence of a gear pouch that is planned to be mounted to the rear of the front seat back.
