Brief Description: Finished J-4 plug except for Ground Wire
Finished J-4 plug except for Ground Wire. Need to order more wire. Need to decide if I will use a relay or a SPST switch to control the grounds of the rear stick.
Below picture is of the strobe power wires. On one side, there is a power wire from the CU coupled with the rear strobe wire. The other two wires are for the left and right wing strobes. Thesed wires a crimped together using a crimp splice connector and then heat shrink added to the outside.
