Brief Description: Started Rear Rudder Pedal installation
Started Rear Rudder Pedal installation. Riveted the rod bearing threaded attachments to the Rudder Pedal Pushrods. Fitted the Idler Arm to the fuselage and match drilled the Idler Bracket to the Aux. Longeron. Deburred the holes.
