Brief Description: Put PIGD Push-on terminals on Aux Fuse Block
Put PIGD Push-on terminals on Aux Fuse Block wire. These wires will run forward to the 4NT1-1 switch that will control whether the engine is receiving Essential power from the Main or Aux Battery. Since I only have a vague idea of where I will be positioning this switch, I cut only the Aux Fuse Block wires. These will run up the right side of the fuselage. I expect to be locating the switch on the right side of the instrument panel or on one of the Mid-Cockpit side panels. I need to find some 1 Amp fuses. They are hard to find. I know that B&C sells them.
