Brief Description: Made and attached 2 ground cables to the tray
Made and attached 2 ground cables to the tray Ground Bus Bar. One cable will attach to the negative terminal of each battery. Later, a ground cable from the "Forrest of Tabs" grounding plate on the firewall will also attach to the battery tray ground bus bar. For further grounding redundancy, I will be attaching two cables to the fuselage directly from the negative terminal of each battery.
