John (Jack) Clark's Web Site
Date:  5-14-2009
Number of Hours:  1.00
Brief Description:  Drilled the Left Tank Access Plate for the Guardia
Drilled the Left Tank Access Plate for the Guardian sensor using measurements from the right tank. I did raise the sensor slightly therefore it should illuminate at some level higher then the Right Tank sensor.
