Brief Description: Drilled and installed the battery mount
Drilled and installed the battery mount. First, I drilled pilot holes in the lower longerons which were used to match drill the outboard angles of the mount. These holes were later match drilled to a larger size 10 for the SS #10 screws that were to be used to secure the mount.
